limp mode?
Old Apr 13, 2009 | 04:22 PM
the cassanova wong's Avatar
Default limp mode?
1999 suzuki quad runner 250 2wd.....runs fine with "lights on"....click key back to just "on" it act as if it just went into limp mode...can't/won't rev and will just bog even worse when you try......click key back to "lights on" runs fine again.....other symptoms which may or not be related....said new battery 2 months ago but keeps going dead...can jump off with cable just fine....have not tested for charge yet or if charging...going to let trickle overnight...thought maybe someone here may have seen this before...thanks in advance!!
Old Apr 14, 2009 | 07:47 AM
LT80's Avatar
LT80 Expert
It would seem that there is a short in the switch. Something is grounding out causing the discharge.
Old Apr 14, 2009 | 08:46 AM
thanks...i should have full charge this afternoon and will begin there...maybe with lights on it is using the lights' ground...hmm we'll see....thanks again
speedbuff
13
Nov 11, 2020 10:16 AM
vandammages@gmail.com
Aug 20, 2020 11:50 AM
