26" grim reaper clearance
I had 26 " mudlites on my 03 vinson,never had a problem.I just put on 26' grim reapers and the tires rub the foot rest frame when turning. Will putting on a 2" lift solve this problem, and does the lift over stress the cv joints and driveline?Thanks
Are you still running the stock wheels or are they aftermarket?
The wheel's offset will have an effect on what will fit without rubbing. It may be easier to change out your wheels, at least the front, for something with less offset...it will also have less effect than a lift on the handling that the Vinson does so well for a quad it's size
