An easy question on where a washer goes on a carb for quadrunner? Im stuck
Old Jun 29, 2009 | 09:45 PM
dsmith222's Avatar
Default An easy question on where a washer goes on a carb for quadrunner? Im stuck
Can someone answer an easy question where a plastic washer goes on a 92 suzuki LT250 carb? I am stuck and I attached a picture of the carb diagram below. I am unsure of where the plastic washer #5 in the diagram is supposed to go? My guess is that it slides onto the pin and right up under the metal clip #4? My only other guess is that you drop the brass pin #18 down through the large spring hole in # 8 diaphram slider and does the plastic washer then slide on the pin when it is sticking down through #8? In other words, does the small washer go down inside the spring hole in #8, or does it go up underneat the little arch down the bottom of #8? This doesnt seem right, I think maybe my first guess is correct. Thank you for any help or clarification.
Attached Thumbnails An easy question on where a washer goes on a carb for quadrunner? Im stuck-suzukcarb2.jpg
green giant
Jul 13, 2017 12:07 PM
armpump450r
Technical and How-To Articles
Apr 1, 2017 06:11 AM
neo27ny
Aug 2, 2015 03:04 AM
sticky123
1) Engine problems..
Jun 14, 2015 07:36 AM
