will ltr450 rims fit a 85lt250R
Old Jul 17, 2009 | 04:33 PM
kingkevin686's Avatar
Default will ltr450 rims fit a 85lt250R
will ltr450 rims fit a 85lt250R?
Old Jul 18, 2009 | 12:37 AM
lt230sman's Avatar
nope.
lt250r's have a huge 4x166 bolt pattern up front, which isnt really used by anything else. and the same goes for the rear; 4x130. not much else uses that.
id just get dwt sport redlabels if i were you. or maybe the dwt ultimates if rolled lips is what youre going for...
hth
Old Jul 18, 2009 | 12:40 AM
lt230sman's Avatar
btw, the ltr is 4x144 up front, and 4x110 in the rear.
you could probably re-drill the holes in the rear, but MAKE SURE you get them centered, and i dont think it will work for the fronts.
Old Jul 18, 2009 | 09:09 AM
Dazeys's Avatar
Can't wait to feel that 130 HP at the dunes.
I think you can put the LTR 450 hubs on the LT250r axle. There are 2 different splines and I don't remember wich spline count you have to have for them to work. I had a set of sand tires for my polaris 500 4x4 and had them redrilled to fit the LT.
Old Jul 18, 2009 | 11:34 AM
lt230sman's Avatar
wow i completley forgot about that!
they should fit, if its an 85-87.5, they use 24 spline wheel hubs. however, they wont work with an 87.5+ axle, since its 26 spline, and once again, pretty much nothing else uses that.
Bratman2
Aug 6, 2022 01:42 AM
STLyamwar
Jul 25, 2020 04:44 AM
fd24
Jan 16, 2019 08:59 AM
PinkFloydEffect
Sep 25, 2015 06:31 PM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
