LT80 Starting problems..
Old Jul 25, 2009 | 09:42 PM
bans25's Avatar
Default LT80 Starting problems..
Hi all,
I have a late 90's LT80 that has starting problems.. If it sits for more than 24hrs the motor "locks up" and I have to keep hitting the starter button till I can get it to turn.. then it turns it locks up again etc.. Once I can get a dozen or so revolutions she spins free and now seems like its flooded out and cranks for a long time till it fires.. Once it fires it smokes heavy for a while.
Is it possible that oil is leaking down and filling the cylinder? Maybe I should try pinching off the lines overnight? is this a common problem with the LT80s?
Old Jul 26, 2009 | 10:00 AM
LT80's Avatar
LT80 Expert
Your motor is filling with fuel.
I'll cut to the chase (instead of a long boring petcock reply)....Go to autozone and get cheap on/off valve (about 3 bucks in the lawn mower section). That should take care of it.
Old Jul 26, 2009 | 02:08 PM
bans25's Avatar
Thanks.. will do! I figured out it was fuel this morning.. one I finally got it cranking over she was pushing fuel right out of the exhaust! I could not believe how much!! I definity need to get a cutoff in there soon.. I dont like the motor being washed out like that!
yagerzzz
Jun 24, 2015 07:45 AM
clsharky
Jun 8, 2015 11:38 AM
Dieseltrash
Jun 6, 2015 09:53 PM
1000gade
May 27, 2015 12:37 PM
Lasher
Jun 8, 2000 11:43 AM
