question for mr lt80
Old Aug 30, 2009 | 08:24 PM
tpmccallen's Avatar
Default question for mr lt80
Just picked up 1990 lt80.A few questions.First question quad wont start unless i pour a little oil in cyclinder first i belive this means low compression is this correct?second i pulled the carb off and rebuilt it but noticed the little black cap inside the bowl covering the brass screws is missing what is the function of this and will it function properly without it.Last i see on ebay that they sell a rebuilt cylinder, piston, rings and gaskets for 159.00 plus core.Have you ever used this or heard of anyone who has?Thanks
Old Aug 31, 2009 | 06:56 AM
LT80's Avatar
LT80 Expert
Yes, prolly low compression.
The brass screws are the jets and it'll run just fine w/o that black rubber thing.
I have indeed seen the cyl kit on ebay. The only problem with it is that you could send in a stock bore cylinder and recieve a maxxed out cylinder leaving you with a cylinder that will be no good once the new piston wears.
I can do this work for less $.
Old Aug 31, 2009 | 02:34 PM
tpmccallen's Avatar
Default mr lt80
Let me know what i need to send you to have this done.Also a price. I have some knowledge but not enuf to reuild it myself.Is it possible to send you the parts and have returned a top end ready to bolt back on.thanks and let me know
Old Aug 31, 2009 | 07:22 PM
LT80's Avatar
LT80 Expert
PM sent.
shimanok2
Jan 29, 2016 07:37 PM
QuadRiders
Oct 22, 2015 04:13 PM
2many2ride
Sep 27, 2015 04:35 AM
merryman
Sep 19, 2015 03:15 AM
Jaymc
Sep 11, 2015 07:45 AM
