i need help with my lt250s
ok i tried to find the plug but if its the one i thinking of you cant see anything thru the hole lol
i found some metal chunks that made it to the bottom so i decided to take the side cover of to check it some more none of the gears on this side have any arrows can you help me?
i will do a comression test later this week
You can use sandpaper instead of a hone, just dont go up and down. As for re-using the rings......You may be up the creek. As for timing, Theres a plug you can take out on the right sidecover on the front side of the cover. Theres an arrow that lines up in that hole. Just keep easing the motor till you see that mark. Then line the marks up on the cam with the head. Thats perfectly in time, But mine is smoking just LIKE yours. lol But I think its my rings.
in all honesty, i'd be safe and order new rings. and definatley have it HONED.
however, are you still at the standard bore? if so, it really wouldnt hurt to go .5mm (0.020") over since 230 cylinders tend to like to get egg-shaped due to the not so favorable rod ratio.
theres a guy on ebay who does good work for $40 plus shipping...
i dont have a lt230s its a 89 lt250s thought that was the plug but there is nothing you can see down it how do i set the timing maybe im doing it wrong ad the valves are opening at the wrong time which could cause it to smoke right?
#15
oh my bad, i meant 250. but theyre absoloutley identical motors anyways except for a bigger bore, 1mm bigger wrist pin, different carb and jetting, and different cam profiles on the 250.
anyways the plug that you found is for servicing the oil pump. the guy who told you to look on the sidecover for plugs is thinking of newer bikes that are set up like this:
and for the timing, theres a score mark in the flywheel (you need to take the stator side cover off to do this) that you line up with a little pointer in the case. at that point the cam needs to have both hash marks level with the head, and the indexing pin that positions the sprocket on the cam needs to be around 11 o clock.
like so:
like so:
Zuki250r
Apr 19, 2000 02:27 PM
