Cracked Case, Will still Work?
Old Oct 18, 2009 | 10:59 PM
tolowfoshow's Avatar
Default Cracked Case, Will still Work?
I hope i can explain this well enough. I bought a 1989 LT250r with a broke piston, once i split the case i found that the broken piece wedged itself between the bottom of the crank and the case. Well, it cracked both cases from the pressure of the piece between the crank and the wall. it is not fully broke but cracked and a little out of shape. My question is do you think that this will matter? is there pressure in the crank area? the cracks look more like hair line and not huge. Is there oil in that area? Need help.
Thanks
Old Oct 26, 2009 | 10:10 PM
NewportHillClimber's Avatar
the only way to know is to put it back together and pressure test it. if it leaks the engine wont run right cuz ull burn tranny oil
Old Oct 27, 2009 | 02:10 PM
victork's Avatar
if its apart bring the cases to a good atv shop to look em over and determine weather theyre shot or not and if theyre fixable go to a good welder as u know small cracks can get worse
Old Oct 27, 2009 | 05:44 PM
Mic_'s Avatar
Thanks
Id catch the cracks while they are small...
I welded mine with aluminum welding rod and a propane torch..working for me for 2 years
Sjrpp
May 2, 2023 03:59 PM
hugemoth
Jul 20, 2020 03:28 AM
Sjrpp
Nov 15, 2019 09:59 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bikedad3
Jul 2, 2015 02:15 AM
