01 vinson 500 running problem
Old Nov 11, 2009 | 03:14 PM
quadhopper's Avatar
Default 01 vinson 500 running problem
hi i have an 01 suzuki vinson problem, it starts, but then fouls the plug after a couple min. it has compression,spark,valves are adjusted,carb is clean,air filter is clean and plug is new. any ideas?
Old Nov 15, 2009 | 12:04 AM
TexasRoadlawyer's Avatar
No Ruts, No Glory
I wasn't aware Suzuki made a Vinson in 2001.
Nonetheless, my first suspicion would be to look at the jetting and/or carburetor. Regardless of cleanliness, it sounds like it is running very rich for some reason. Take the bowl off to see if the float is working correctly, and then check to see that your jets are clear and that they are the correct size for your stock engine (did you buy it used?)
wildbill59
Jun 9, 2015 02:28 AM
generalpops
Jun 5, 2015 08:23 PM
garyt1975
Jun 5, 2015 08:53 AM
generalpops
Jun 3, 2015 08:25 PM
blaze_master
May 26, 2015 11:18 AM
