lt230
Old Dec 7, 2009 | 01:25 PM
fatboytank320's Avatar
Default lt230
I got a lt230 last week, it had been sitting for a while so I cleaned the carb out, changed oil and put fresh gas in it. Pulled the plug to see if it was firing and it was so I placed the plug back in, choked it and kicked it a few times and it start for about 2 seconds and died as soon as I tried to give it gas. It revd for like a split second before it croaked. So I tried to kick it over again and could tell it wasnt firing. So I pulled the plug back out and its not firing now and I cant seem to figure it out, I tried 3 different plugs too and still a no go. I pulled the plastic off and the tank and tracked down all the wires to make sure everything was plugged in and they were. Even took off the stator cover and wiped off the flywheel and made sure there wasnt anything messed up. Any suggestions as to why its not firing? Thanks.
Old Dec 7, 2009 | 06:15 PM
bashr52's Avatar
You didnt bump the kill switch at all did you? Is it loose at all that mabie the vibration from when i did fire may have wiggled something loose? How did the spark look when it was firing?
Old Dec 7, 2009 | 07:34 PM
NO I didnt bump it, its still on run and the switch is on. Spark was a blue color when it was firing.
Old Dec 7, 2009 | 09:00 PM
bashr52's Avatar
Hmm, a nice strong blue spark wouldnt just crap out, if it was weak yellow or something I could see it happeneing. Did you verify all the connections were tight to the coil?
Check the vault, there's a good wiring diagram in there and the specs for testing the various components.
Old Dec 7, 2009 | 09:28 PM
lt230sman's Avatar
its possible that theres a pretty major air leak. check your carb boot for cracks.
Old Dec 7, 2009 | 09:56 PM
atvman29's Avatar
So there's no spark anymore? Maybe there was a short and you cooked something?
Old Dec 7, 2009 | 10:07 PM
I hope not! lol but I may have, i'll check out the coil connections tmrw, they had the ground wire just tied around it and I have made a clip for it to plug in and maybe its not making good enough connection or something idk.
lonerider856
Oct 13, 2023 03:45 PM
Shooterj2003
Jun 21, 2015 07:51 PM
scaldwellk
Jun 19, 2015 05:08 PM
230Srider
Jul 17, 2003 06:30 PM
QuadDude05
Jan 3, 2001 01:35 AM
