93 lt-4wd vault ?
Old Dec 22, 2009 | 02:56 PM
robs ace's Avatar
Unhappy 93 lt-4wd vault ?
I seen the lt-230s vault on here many times. but none for my machine, Ive read up on spark no spark found great help from all. I think i got that figured out then.... spark/fuel wont start.... found help with compresson mine reads 34psi. I know I know!!! no good. So.....found ring gap 0.70mm limit mine is at 0.64mm. FLAT AZZ WORE OUT. understandable 17yrs old same stock piston never been apart. Ok getting ready to put it together after Xmas so im trying to find out spec. on timing torc ect. ect. thanks everyone
Old Dec 27, 2009 | 07:07 PM
sugarhead's Avatar
If you go to your library robs look for a suzuki fwd clymer manual,that should help you.My library has a book called how to fix atvs by clymer its got everything almost from the big 3.Its an older 1 from 87 but I believe all the lt an fwd engines are basically all the same year to year.Hope this helps bro
Old Dec 28, 2009 | 02:47 AM
robs ace's Avatar
Thanks ill look in the morning i didnt even think about the lib. ill let you know.
thlmrk
Nov 17, 2014 02:48 AM
TimberedWolf250
Apr 19, 2011 10:34 PM
bradt530
Dec 2, 2010 09:36 PM
roempty
Aug 3, 2010 12:16 PM
ChristopherD
Mar 5, 2009 02:25 AM
