Vinson problem
Old Dec 24, 2009 | 04:10 PM
tydogg's Avatar
Default Vinson problem
I have a 06 vinson with low miles, parked it about a month ago and went to use it today and it wouldn't start. I pulled the plug and managed to get it running but only with the choke on, when speeding up the motor it also backfires, and will not idle. It was fine when parked earlier and don't really want to take it to the dealer.
Old Dec 24, 2009 | 08:27 PM
KQ400Pilot's Avatar
Time to pull the carb, completely disassemble and clean every port, jet, etc.
Old Dec 26, 2009 | 06:08 PM
NewportHillClimber's Avatar
yep gas can go bad in two weeks now a days. clean the carb real good and throw old gas away
Old Dec 26, 2009 | 09:15 PM
tydogg's Avatar
Thanks guys, I decided I will just take it to the dealer. Not much time to deal with it right now, just didn't want to take it in because of the 2 hour drive. Oh well, they can deal with it.
Old Dec 27, 2009 | 09:45 AM
Dazeys's Avatar
Can't wait to feel that 130 HP at the dunes.
It would take less than the 2 hour drive to clean the carb. First try runnig the pecock on PRI. .Then try pulling the fuel line from the carb and turn the petcock to PRI. Gas should flow free. Take a spay can of carb clean and a soft wire and spray into where the fuel line hooks on the carb. While spraying swish the soft wire around. There is a screen in there that can plug. Good time to install a filter in that line. You can drain the float bowl with the carb still on the quad. There is a drain screw at the bottom of the bowl. Just loosen it a few turns to drain. You can loosen the carb boot and turn the carb sideways to remove the float bowl and clean all the jets.
Old Dec 30, 2009 | 12:09 PM
boomerdog's Avatar
Yep Sta-bil is mandatory these days with that dang ethanol in all the gas.
Old Dec 30, 2009 | 04:26 PM
i wont use fuel stabilizer in my fuel. the fuel stabilizer eats brass. be very careful. i had to machine a float valve seat for a mojave for a customer once. it was either that or pay 450 for a new carb cuz u cant buy the seat from kawy.
Old Jan 2, 2010 | 04:10 PM
automanic's Avatar
Cool i had the same issues
turned out to be an intake valve on my 05 vinny, pulled carb , not the problem got local bike mech, 140 buks later runs better than ever....good luck.
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
