250r Rings
Old Mar 12, 2010 | 06:58 PM
lt230sman's Avatar
Default 250r Rings
alright guys im back, and as always, im bewildered!
just pulled apart the topend on the ol' 250r (had ZERO compression, was impossible to start without tugging it around for a while, and yet somehow ran with decent power!?). and i found something quite strange. my rings are worn way out of round. the piston and cylinder walls look beautiful, and im pretty sure that there's no way the cylinder is this out of round. the bike was just bored 2mm over and has no more than 50 (hard) hours on it. also, the notches in the rings that are there to clear the pins in the cylinder (to keep the ring end gap from rotating) are worn off to one side.
is this normal? im super broke at the moment and im planning on only replacing the rings for now...
Old Mar 13, 2010 | 09:21 AM
LT80's Avatar
LT80 Expert
I'd say normal.
Old Mar 13, 2010 | 01:04 PM
lt230sman's Avatar
ah thats what i was hoping for lol!
Old Mar 14, 2010 | 11:33 PM
2strokezilla's Avatar
I know how it is to be super broke and your quad broke also...but to do it right would be to bore it next size up with new piston rings and pin and bearing unless you are at last bore. my 250r is low on compression also and can't fix right now plus my quadzilla has a cracked jug that I need to repair.
Old Mar 15, 2010 | 07:55 PM
lt230sman's Avatar
im at the last overbore
Old Mar 16, 2010 | 10:54 AM
m44's Avatar
m44
couldnt you just resleeve the cylinder
Old Mar 16, 2010 | 11:48 AM
LT80's Avatar
LT80 Expert
I'd check the piston to wall clearance. If .010 or under, I'd ring it.
Not what I'd do for a long term fix but it should get you by for a lil while.
Old Mar 17, 2010 | 11:24 PM
haven't seen rings like worn like that its like they walking around a lot in the ring grooves wondering how much play you have does the piston show any signs of slapping the walls?
Joe454
Nov 20, 2020 01:19 PM
dunerv8
Technical and How-To Articles
Sep 14, 2015 10:11 AM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
