eiger clutch replacement
Old Apr 13, 2010 | 09:03 PM
pro94lt's Avatar
Default eiger clutch replacement
Well I'm gettin ready to replace the clutch on my eiger, I guess 2500 miles of 26 inch mud lites and to much pullin has got the best of it. Just wondering about how much it will cost, how long it will take and if thiers any special tools i'll need? I've never done a clutch on a wheeler so chime in on any tips.
Old Apr 18, 2010 | 12:31 AM
poolsean's Avatar
If you have the 5-speed semi auto tranny, you'll need to pull the primary clutch out to get the clutch plate cluster out of the carriage. An impact wrench or air tool will make it easier to loosen the nut. I don't recall the size of the socket but its bigger than 1" for sure.
Make sure you soak the fiber clutch plates in clean oil at least 24 hrs in advance.
It shouldn't take very long if you have the right size socket and tools...maybe about an hour.
Check your primary clutch shoes and main housing for wear. There are 5 or 6 clutch shoes (these are metal "arms" for a lack of a better word that press out against the housing when the engine revs). If this is worn, it's not a cheap part and you must get the entire assembly.
If you have the auto tranny, can't help you there.
I can send you some photos if you need.
Old Apr 18, 2010 | 11:58 AM
pro94lt's Avatar
Don't sound to bad, I'll get on it sooner or later
ghost civic
Jan 15, 2020 07:43 AM
baysport
Jul 23, 2015 11:37 AM
ghost civic
Jul 15, 2015 10:48 PM
clsharky
Jul 13, 2015 02:07 PM
coolguy420
Jul 10, 2015 01:17 AM
