Suzuki Vinson ?
Old Apr 25, 2010 | 09:10 AM
tds777's Avatar
Default Suzuki Vinson ?
I just got a 04 Suzuki Vinson, changed the oil and done other service work. My main question is about the crankcase oil capacity, Owners manual states 3.8 quarts with filter change, but it completely fills the sight glass. Is it supposed to be like that?
Does anyone know if 3.8 quarts is correct and is it supposed to completely fill sight glass when it running or engine is off?
Old Mar 7, 2011 | 09:17 PM
06cincyvinson's Avatar
i have a 2006 vinson and when i change the oil it does completely fill the sight glass.
Old Mar 8, 2011 | 07:22 PM
papahouse's Avatar
my 03 vinson is the same way
Old Jul 19, 2011 | 05:50 PM
mrbigcheezzymac860's Avatar
i have a 05 vinson and you want the oil level between the low and full marks on the glass. If the glass is fully full you got to much oil in it
Old Jul 19, 2011 | 10:15 PM
ROWDY33's Avatar
I have an 04 Vinson and it has a dip-stick. 2.9 US qts with filter right from my owner's manual.
Old Jul 19, 2011 | 11:21 PM
95wolv's Avatar
I did a web search and also came up with 2.9 quarts with filter change. If you are putting in 3.8, thats almost a quart too much. Sight glasses are almost always meant to be at about half level to indicate correct full, when running, it may show a bit lower, as the oil will be up in the motor, but at rest it shoul show about half full after a minute to allow oil to drain back to sump.
VABrute
Jan 6, 2016 07:39 PM
clscott84
Sep 21, 2015 10:16 AM
merryman
Sep 19, 2015 03:15 AM
jsmit116
Sep 18, 2015 10:34 PM
Sep 1, 2015 11:59 PM
