What are the bad things about a 86 lt250r
Old May 12, 2010 | 07:23 AM
liljoker1994's Avatar
Default What are the bad things about a 86 lt250r
I got a lt250r quadracer what are all the bad things i should check befor rideing it alot
Old May 14, 2010 | 07:39 AM
2strokezilla's Avatar
hey lil joker what bad things are you talking about? didn't think there was anything bad about a LT250r
Old May 14, 2010 | 09:31 AM
just looking for things that other people have had promblems with that i should check befor taking it out of state
Old May 14, 2010 | 09:46 AM
only thingI can think of is let it warm up before you ride those 85-86 LTs have been known to seize if not warmed up
Old May 14, 2010 | 09:52 AM
ok ya i keep mine in a heated shed and have its own heater for outdoor rideing thx though do you know a good place to order tires cheap and swing arms
Old May 14, 2010 | 04:25 PM
Scooter86's Avatar
Knows Old ATV Questions!
What he means is you need to let the motor idle and warm up a bit. 2 strokes tend to seize if the engine is not up to operating temps before you start hammering the throttle. The LT has a few quirks, but just give it a good once over checking for loose bolts and excessive play. My chain tensioner could be a bear if any crud got into it. Other than that mine was pretty reliable.
Old May 15, 2010 | 10:17 AM
TLC's Avatar
TLC
I have a Dirtwheels magazine that mentions the old 500 2 strokes had a tendency to crack at the frame members,since the two ATVs may share the same frame it would be something to keep a eye on.
Old May 15, 2010 | 02:23 PM
Scooter86's Avatar
Def. not the same frame, but that actually is a common problem amongst all the Quadracers. You should pay special attention to frame at the footpeg area. Also, my frame and pretty much every '85/6 I have seen all rust through along the bottom side of the bottom rails. I took mine to a shop and had the frame reinforced and welded in those sections.
Old May 15, 2010 | 05:11 PM
ok thx for the info guys so manly just watch out for the frame cracking or rusting
Reactant
Mar 30, 2022 02:08 AM
COFatboy
May 2, 2020 12:06 AM
toonces
Oct 16, 2019 12:11 PM
ScopeZ_
Jul 28, 2015 01:44 AM
DeFox500
Jul 26, 2015 06:32 PM
