Problem with 2004 Suzuki Eiger 400
Old Jul 25, 2010 | 11:17 PM
PA452's Avatar
Default Problem with 2004 Suzuki Eiger 400
Hey guys, I have a problem with a 2004 Suzuki Eiger 400 4x4.
Basically I'm getting sort of a "whirring" sound from the engine. It came on over time and is now to the point where it's pretty much always there and very noticeable. It follows the RPMs through the entire throttle range, though it is more noticeable when not at idle. The sound is present when in neutral and not moving.
I cannot pinpoint the location at all so far. I've read that the timing chains on these quads stretch fast, and I have a friend who made that suggestion first. I pulled the chain tensioner off and it was not maxed out, but it was about 2/3s to 3/4s extended. I was thinking maybe that's as far as the guide will move? Maybe it doesn't have to be all the way extended to no longer be working?
Since I had that tensioner off, I swear the noise is worse and much more noticeable, but honestly it could just be my imagination.
Any ideas would be greatly appreciated.
Thanks
Old Jul 26, 2010 | 08:30 AM
RonV's Avatar
Are you certain it's not in the CVT? I had the non-movable plate on mine fail and it started with a slow noise and eventually built up to a loud racket. It would be mostly present when on the throttle. Of course, if yours is manual shift, you wouldn't have a CVT. I'm not much on engine internals, so hopefully someone else can chime in regarding the timing chain.
Old Jul 26, 2010 | 03:39 PM
PA452's Avatar
Yep, it's a manual shift transmission.
Thanks for the reply.
Old Jul 26, 2010 | 11:57 PM
Scott267839's Avatar
I have 2002 and 2005 Eigers and have not had any engine problems execpt flywheel magnets on the 2002. Have not touched the timing chain. So sorry can not help.
But it does sound like your on the right track --something wearing out over time.
I have not heard that the cam chains wear out fast.-- Thanks.
Old Jul 31, 2010 | 04:27 AM
beart0y's Avatar
How many miles?
Old Aug 9, 2010 | 09:46 PM
PA452's Avatar
Originally Posted by beart0y
How many miles?
I'm approaching 2600 with it.
Old Aug 20, 2010 | 07:28 AM
jwernatl's Avatar
PA452 - What did you figure out?
Jmuddin284
Jan 19, 2026 07:16 AM
jaime511
Jul 19, 2015 01:58 PM
Gtsordo
Jul 13, 2015 10:38 PM
clsharky
Jul 13, 2015 02:07 PM
jettman
Jul 6, 2015 12:16 PM
