LT250r 92 HElp
Old Aug 2, 2010 | 03:46 PM
dirtylt250rr's Avatar
Default LT250r 92 HElp
hey guys ,i need a little help or maybe alot ,I just picked up a 92 lt250 r,fmf pipe ,starts right up first kick,lots of compression,new carb,pulls wheelies all that ,but .....seems to have no mid power or top end just a dog, seems very flat..no power band at all ....I also have another 92 250 r low compression that would eat this bike ,still has stock exhaust,,,,,,,,what makes them flat in power like that??jets ?/power valve??other wise this quad is dam near like new .......any help would be great .....cause this sucks i cant even beat a 400 ex like my other LT250 r smokes them all day......
Old Aug 2, 2010 | 05:31 PM
sdm111's Avatar
2 strokes or 4
Have you checked for cracked or broken reeds. I have a Honda 250r that did the same thing you're describing and it ended up being the reeds. Put a set of v force 3's on it and it's fine now.
Old Aug 2, 2010 | 05:45 PM
how do i check them ?/
Old Aug 2, 2010 | 06:41 PM
sdm111's Avatar
2 strokes or 4
Take the carb. off, take the intake boot off and pull the reed valve out the cylinder and check the reeds for cracks, warpage, or holes in them. It is said to change the reeds once a year so if they haven't been messed with they are probably messed up. Just looking at it between the intake boot and cylinder there will be what looks like a spacer plate that is the reed valve. If it's been there a while it may take some effort to separate it from the cylinder.
Old Aug 3, 2010 | 11:13 PM
fixed sweet......thanks sdm ...turned out the dude that rebuilt that new motor never set up power valve .....now it opens at 5500 rpm ,during checking in the shop ,i could rev the S$%^ out of it dam thing wouldnt open minor tweak all good
Old Aug 4, 2010 | 05:01 PM
sdm111's Avatar
2 strokes or 4
Good to hear it was an easy fix.
Levi Enstad
Sep 26, 2015 08:00 AM
Halffast17
Sep 11, 2015 02:30 PM
LTqracer
Sport Quads
19
Jun 2, 2004 07:20 PM
donpeter
Apr 4, 2001 12:31 AM
Steve10
Aug 2, 2000 03:32 PM
