anyone ever had a vibrating problem
Old Mar 8, 2001 | 07:15 PM
LBZfreestyler's Avatar
hey i have a 1986 lt250r quadracer. the dam thing vibrates so bad!! the couter balancer weights are in line. anyone ever have a problem like this happen to their Lt's? god it is so bad you can't ride the thing for more than 2 minutes. any suggestions would be great. later
Old Mar 8, 2001 | 08:48 PM
bayou220atv's Avatar
check your engine mounts for tightness, and/or a broken engine mount
Old Mar 8, 2001 | 10:21 PM
love250x's Avatar
my 86 Quadracer vibrates bad too. my foot falls asleep after 3 minutes. But im just gona get used to it.
Old Mar 9, 2001 | 01:27 PM
lt250rrules's Avatar
hi,
I have a qracer92.I had the same problem.
1-look if your crank bearing are in good shape.You have to push your flywheel up and down.If they are good itsn't supose to move and if
it move you must change them
2-look if your cranck isn't false. You have to remove your flywheel.Put a dial indicator on the taper part of the crank.turn the crankshaft with your hand.You must read under .003inches.If you do not your crank must be rebalanced.
3-align mark on your counterbalance gear
on mine i did all that and it was shaking again
after a lot of research i found that marks on my gear were wrong.Nobody can explain me why
so if you do step 1,2 and it seem ok try this:
remove sparkplug and turn your engine toput your piston at the up of the cylinder.On the flywheel side look where your balancer(half moon)are.IT MUST be at the opposite side of your cylinder.if it is not, align your counterbalance this way
you will resolve your problem.
Old Mar 10, 2001 | 01:33 AM
juggalo's Avatar
mine has no counterbalancer and it vibrates a ton. but i am so used to it by now. i can ride all day with no fatigue. and i can hop from my LT to my friends 400EX and not really notice the difference. there is a huge one but i just don't pay attention to it.
Old Mar 10, 2001 | 03:19 AM
dual-sporter's Avatar
mt brother is about to start working on his, he asn't had a chance to all winter. it started vibrating real bad when we were at the dunes last time all of a sudden, so we shut it down & towed it in.
i called trinity, CT and LRD they said to check a few other things too: the bearings on the counterbalancer may be bad & need replacing, or the nut on the counterbalancer may have come loose.
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
