How much to refill the nitro on my 86 LT250R's rear shock?
Old Mar 8, 2001 | 10:36 PM
love250x's Avatar
Anyone know how much it is to refil the nitro on my Quadracer's rear shock? It needs it so bad, the rear end drops 6 inches when i sit on the seat and i only weigh 130 lbs. Thanks
Old Mar 8, 2001 | 11:39 PM
Guest
Guest
Posts: n/a
It shouldn't be more that $10 dollars or so to recharge a nitrogen reservoir. That's what I paid when someone let the gas out of my TCS's.
Old Mar 9, 2001 | 08:44 PM
donpeter's Avatar
My 92 QR did the same thing, I needed to change the oil and a recharge. To test it turn your rebound dampening all the way stiff, push rear down as hard as you can if it doesn't come up real slow then you need the oil and nitro changed,if it does come up slow then all you need to do is crank down on your preload adjuster.
Bratman2
Aug 6, 2022 01:42 AM
mywifesquad
8
Sep 21, 2015 08:20 AM
OutRacing
Technical and How-To Articles
Sep 3, 2015 07:49 AM
snowolson
Aug 31, 2015 03:51 PM
SixSpeed5
8
Aug 2, 2015 05:38 PM
