86 Quadsport 230
the 230E and 230S frames are completely different. Almost night and day different if you look at the motor mount in the front under the header pipe. the E model has a bolt hole for a long bolt similar to the bolt that runs through the footpeg and skid plate for the bottom motor mount. here is a couple of pics of how to tell the difference between the E model frame and the S model frame.
very possible!! wheres the numbers on motor?? all i found are 1500 on case below oil cap,..an on bottom lip of jug its got 159 CMz id like to order a susuki book for it an a new carb,..an tune up an oil change supplys but need to know for sure what i got?? been reading the big thread,an mine is awful weak compared to what some say theres run....
Could that CMz actually say CM2, as in 159cc engine? That sure looks like a 230S or E frame. The S did not come with a rack, but I thought it was a rear rack for the E model? I think it is very possible someone transplanted a 160 motor in that frame. The first 160 was made in 1989, but the plastics are more the "next gen" styling from what is in your pics.
#15
#16
well the mystery is solved. its an 89 lt230e frame witha lt160 engine on it.
