LT250R Rear Suspension Questions
Old Apr 30, 2011 | 07:56 PM
PinkFloydEffect's Avatar
Lightbulb LT250R Rear Suspension Questions
Got a few questions, my rear shock linkage pivots side to side is there suppose to be play here?
Also it's all grimy looking because my rear shock spits oil, I found a replacement seal but how hard are they to replace?
I'm assuming the overflow bottle only holds air? I see a stem coming out of it do you fill it to increase stiffness?
I have a spring compressor but the oil inside is what I am really wondering about, Thanks.
Old May 30, 2012 | 11:07 PM
BUMP
I figured out the reservoir is filled with oil, I bought some shock oil but can not figure out how to replace the head seal:
The head seal is held down with a c-ring/clip but I can't seem to remove the ring, almost as if the seal has been pushed up farther then normal closing the gap a bit where the ring clips in. I tried using a socket to knock the seal down a bit but I don't want to damage the body or anything, any advice?
Bratman2
Aug 6, 2022 01:42 AM
WilliamBos
Jul 13, 2015 02:11 PM
tporath
Jul 11, 2015 12:31 PM
rcappie4
Jul 10, 2015 04:54 PM
Rider252
Jul 6, 2015 03:37 PM
