1985 lt230s Help Please!!!!
Old Jul 7, 2011 | 10:02 PM
mrgrimm96's Avatar
So got it all back together idles great but once in awhile it will backfire out the carb and when it first starts up if i hit the throttle it stalls but after a few min of warming up its fine have no problems when riding it just when it starts up any ideas i thought it might have something to do with intake valve not sealing right i replaced al the seals and cleanded up the valves
Old Jul 8, 2011 | 01:49 AM
Trailrider230s's Avatar
Originally Posted by McFarling
who said i was stopping because of me?
usually stopping becuasue someone else got stuck.
again i said no offense. and gear selection and feathering the clutch with the brake kinda helps. usually where i ride, we use the 4 second rule. we ride old high wall mines and stuff of that nature, where the trails are steep and almost always have a minimum of a 100 foot drop on either side. i have only been riding a clutch drive 230 since December of '09.
and here is a useful tip, always plot a course that will get you around an object, even if its another rider, but safely. i am still recovering from a bruised brain and several fractures because i didnt think ahead and took a jump wrong and turned my 230 into a Christmas tree bulb, then had it land on my head and chest. so always think ahead at least 4 seconds.
Old Jul 8, 2011 | 01:54 AM
sound like you gotta really cold natured 230. your intake valve may have somethin to do with it. 230s are notorius for bending intake valves. i would have the valve seats recut and new valves put in, maybe new valve guides as well. but thats just what i did during my rebuild, still waiting for my crank to come back from the shop.
Old Jul 9, 2011 | 08:45 PM
drummond1081's Avatar
Could be your carb. My dad owned mine before I took it over. He always said it was cold hearted. When I first got it it was. I eventually got so that I dont have to even use the choke, I just give it about 1/4 throttle and it starts and stays that way.
It took me a long time to get to know my carb. You can clean it up real well, take all the jets out and clean, clean, clean. I like to take the choke and others out and clean em too. If you turn your pilot screw out 2 turns, and start your quad. you can then fine tune your pilot screw. For me it is usually around a 1/4 of a turn either way. It sometimes takes away the backfire.
The backfiring though, I agree could be the intake valve not sealing properly. I am just glad I live in Michigan where places are hurting for money, and normally we can get things done a little cheaper.
lonerider856
Oct 13, 2023 03:45 PM
Dammar
Aug 26, 2015 07:12 PM
Dustinyoungs
Jul 24, 2015 07:18 AM
CRamshaw777
Jul 18, 2015 05:46 PM
HondaR24
Jul 16, 2015 10:45 AM
