'07 Suzuki Z400 Lightened Flywheel Timing
Old Nov 2, 2011 | 08:45 PM
Raptor450's Avatar
Default '07 Suzuki Z400 Lightened Flywheel Timing
I am putting this engine back together on the Z400 and I am trying to set the timing/install the cams. The manual says set the flywheel so the "t" mark is visable thru the peephole in the stator cover. This engine has a lightened flywheel and there is no 'T' stamped on it. I was wondering how do you know when it's the correct TDC on this Flywheel?
Old Nov 3, 2011 | 10:06 PM
Raptor450's Avatar
I think I figured it out, for future reference, there is a notch on the flywheel at TDC that you line up with a notch on the engine case. There is not a T stamped into the flywheel, I had to remove the stator cover to see the notches. It will be a good idea to stamp a T on the flywheel so you can see it thru the peep hole next time.
jaime511
Jul 19, 2015 01:58 PM
clsharky
Jul 13, 2015 02:07 PM
sara durrant
Jul 6, 2015 05:32 PM
yambam13
Jul 4, 2015 01:49 PM
