87 lt230eh loss of power
Old Dec 2, 2011 | 11:52 AM
danjotto's Avatar
how do i get it more air? the adjustment screw on the carb seems to have no affect when i adjust it. and its not air filter cause i took it off for working on the carb
Old Dec 2, 2011 | 01:25 PM
danjotto's Avatar
my compression is about 80 psi its low but it should still run right?
Old Dec 2, 2011 | 02:36 PM
MIsuzukilt230s's Avatar
Sounds kinda low, and since you have a knock it sounds like its time to pull the top end apart anyway :/
Old Dec 2, 2011 | 02:41 PM
When you cleaned the carb did you put a rebuild kit in it? I tried cleaning mine multiple times without much success, as soon as I rebuilt it with new jets and gaskets my issues were solved. I found a kit for around $15 or so on ebay.
Old Dec 2, 2011 | 02:56 PM
  #15
danjotto's Avatar
no i just cleaned the carp really good. and when you say "pull the top end apart" what do you mean (rings and piston or could it be something else)? and i also just for the hell of it checked my spark again and no spark now at all but had spark a couple of days ago. how do i check the cdi and the ignition coil maybe i did it wrong last time or something
Old Dec 2, 2011 | 03:11 PM
  #16
LT80's Avatar
LT80 Expert
OK. Let's face it, it could be a few things.
I thought I'd start off with the easy stuff.
Compression (like stated), valve problem, coil/cdi...????
When things quit when hot, I look at the coil/cdi.
Just seen the updates:::
"Sounds kinda low, and since you have a knock it sounds like its time to pull the top end apart anyway"
I agree but I think before I tore it all the way down, I'd check the valve adjustment.
You use a ohm meter to check the coil/cdi.
Maybe somone in here has the specs.
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
Minimod
Sep 10, 2015 08:03 AM
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
byronman
Sep 6, 2015 06:34 PM
