suzuki lt 250r help
Old Jan 3, 2012 | 09:04 PM
  #21
suzuki250r315's Avatar
lol, the ride went good, the engine ran great, the only problem is the rear wheels seem to whobble, i tightened the axle nuts and lug nuts, and it still whobbles, any ideas
Old Jan 4, 2012 | 05:26 AM
  #22
Scooter86's Avatar
Knows Old ATV Questions!
When you say "axle nuts," are you referring to the castle nuts on the ends of the axle that hold the hubs on, or the nut near the bearing carrier on the brake side? If all of those are good and tight then the thing to do is get the rear tires off the ground and look for play in the carrier(needs new axle bearings and possibly a carrier) or the hubs themselves(splines may be worn out on either the axle, hubs, or both.) You could also have a bent axle or rim.
merryman
Sep 19, 2015 03:15 AM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
Sep 1, 2015 11:59 PM
