need advice
Old Mar 8, 2012 | 07:47 PM
rockcrawler32's Avatar
Default need advice
yes i have a 2000 suzuki quadmaster 500 and i read it is suppose to have descent engine breaking , but has none it just coases when let off the gas , even worse on a downhill any thoughts would be helpfull
Old Mar 9, 2012 | 05:50 PM
Twin_Stacks's Avatar
Centrifugal clutch getting worn? I have an older Bayou that does that. If you tweak the throttle, does it catch?
Old Mar 9, 2012 | 08:08 PM
no it does not. but it runs ok when i put it into gear its just a slow doesnot seem to have that get up and go , but it moves with no hesitation
Old Mar 10, 2012 | 04:52 PM
If it's down on power then it's most definitely not the clutch. I'd check the compression and make sure the fuel system is clean.
Old Mar 10, 2012 | 07:20 PM
heythanks im rebuilding the carb as we speak, so i hope that helps cause i also notice a real bad fuel smeel when starting and i had fuel in my air box
Old Mar 11, 2012 | 08:23 PM
I'm no expert but that's what I'd do. Best of luck.
ultangler
Nov 30, 2024 01:35 AM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
kodiacrunner
Oct 4, 2015 11:52 AM
wrencher82
Sep 28, 2015 10:02 PM
