LTZ-50 Excessive Fuel
Old Apr 21, 2012 | 07:52 PM
  #21
vetteboy86's Avatar
I took the carb apart. It appears that the main jet from the rebuild kit is smaller than the one I took out. So I swapped the main and pilot jets back. The quad runs a good as it has so far. However if I hold the rear wheels off the ground I can gradually increase throttle right up to the point the rev limit comes in. Instead of staying on the rev limit it will die-comeback to full throttle- die- come back to full throttle and keep this up. I took a short video but it doesn't appear that I have forum rights to post. I'd be happy to email to somebody to post for me.
Old Apr 21, 2012 | 11:31 PM
  #22
vetteboy86's Avatar
2006 Suzuki lt-z50 - YouTubeVideo of LT-Z50
Old Apr 23, 2012 | 01:45 PM
  #23
vetteboy86's Avatar
Anybody?
I called the local dealer. They say then can test the coil, but not the CDI. I wish I could test this thing before sinking the money into a new one. The service manual doesn't really have anything that I've seen as far as testing it either.
Thanks,
Craig
Old Apr 23, 2012 | 02:11 PM
  #24
LT80's Avatar
LT80 Expert
You need to call Chris Grissom..Suzuki of Paris Tenn.
If he can't help, nobody can.
Sorry, don't have his number.
Old Apr 23, 2012 | 02:33 PM
  #25
vetteboy86's Avatar
Thanks for the lead. I'll research it and see where it goes.
Hopefully I'll get some help.
Old May 9, 2012 | 07:48 AM
  #26
vetteboy86's Avatar
I finally have some closure to this mess.
I purchased a PROCOM CDI unit. This unit does not work on my 2006 LTZ50. I called PROCOM before purchase, and they told me that it would.
I reinstalled the OEM CDI unit and began more work. I used an oscilliscope to verify the pick up coil pulse, and also the pulse generated by the CDI. At higher RPMS, the CDI unit quit functioning.
All this time, I was conducting tests with the battery removed. This was a mistake. This 4wheeler requires the battery to function correctly. I purchased a new battery, installed, and the 4wheeler runs as it should now.
The PROCOM CDI unit still doesn't function.
ltrmc02
Aug 22, 2021 02:34 PM
SureCanUSA
Sep 14, 2015 09:57 AM
PrairieDog126
Sep 12, 2015 06:53 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Elkaholic
Sep 6, 2015 02:44 PM
