Eiger LTA 400 Transmission oil amount
Old Jun 15, 2012 | 05:47 AM
SirOrigami's Avatar
Default Eiger LTA 400 Transmission oil amount
EDIT: LTF 400 not LTA
I have recently changed oil in both rear and front.
Changing rear was confusing since I have never encountered the small drain screw before that tells you when it's enough oil.
Rear was about 1.8dl oil
Front transmission did not have that "over fill" screw so I just poor in the same amount I drained. About 1,2 dl. This seems to me like it's to little?
The total capacity is about 7,5 dl when you fill it so it runs out the filler hole. I have tried =)
Any one got any idea how much oil it's supposed to take?
Old Jun 15, 2012 | 10:25 AM
SirOrigami's Avatar
Ok so i Found the PDF online Service Manual,
(front Diff) Differential gear oil 300 ml (10.1/10.6 US/lmp oz)
(Rear Diff) Final gear oil 350 ml (11.8/12.3 US/lmp oz)
Old Jun 15, 2012 | 06:58 PM
Rancher247's Avatar
I don't measure the amount, I just wait until it comes out the full hole in the back, and the fill hole in the front. Wait for it to stop trickling, and put the bolt back in.
Old Jun 16, 2012 | 12:38 AM
SirOrigami's Avatar
Funny thing is. In the front diff there is no full hole.
Old Jun 16, 2012 | 05:37 PM
Rancher247's Avatar
That's because unlike the rear diff, the front diff fill hole is low enough to be the full hole as well. If you look in the manual it says this very thing.
Old Jun 18, 2012 | 07:13 AM
SirOrigami's Avatar
No its not, its the same height as the Rear diff hole, If i fill it up till it starts to drip out of the filler hole it contains 8dl Oil.
In the Manual it says there is a Full Hole, Just like on the rear Diff but there is none.
Jeff Roper
Feb 1, 2022 11:48 AM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
r1pilot83
Sep 27, 2015 07:38 PM
2many2ride
Sep 27, 2015 04:35 AM
WilliamBos
Sep 22, 2015 04:07 PM
