Need help with Suzuki Quadrunner Electric Problem
ive been recently trying to fix my suzuki quadrunner. i got it home and just for fun tryed staetin er up..(prolly not the best idea id been siting for 5 years or more) and it started and stalled everytime. The next morning i had no power at all. so i figured it was the battery so i bought a new one i put that on and still nothing..at all..please help ive heard something about a cdi box? but dont know anything about it
Thanks
Thanks
matyb.. Hi i am no expert but if the engine is not turning over i doubt its your CDI .. most likely a bad ground or fuse .. check all fuses then clean, scrape tighten and inspect every ground wire... also check the ignition switch.. try bypassing the starter relay by running a jumper directly to the starter ... then please post an update.. hope this helps
ranvette
Jul 4, 2015 06:13 PM
