87 suzuki lt230e quadrunner- timing issue!
Old Oct 23, 2012 | 09:11 PM
trober_603's Avatar
Default 87 suzuki lt230e quadrunner- timing issue!
ok i have an 87 suzuki lt230e quadrunner and i just recently put new valve seals and piston rings in it, and i didnt really study up on the timing thing but i just marked the chain and gear with a marker hoping it would line back up. When i put it all back together it starts just fine but about half throttle or if u hold the throttle in a set position it cuts out/misses. so i believe i messed up the timing! does anyone know how to fix the timing? i could really use some advice/directions on how to time it back properly! thank you
Old Oct 23, 2012 | 11:15 PM
JustRandy's Avatar
The timing marks are on the cam and should be parallel to the head at TDC like this
And you can't have it 180 degrees out because the plug fires every TDC.
Old Oct 24, 2012 | 07:12 AM
trober_603's Avatar
Ok so the cam bolt has to be at about 11 o'clock? If not iT would be about 5 o'clock and bout out 180 degrees?
Old Oct 24, 2012 | 07:18 AM
JustRandy's Avatar
You don't see the marks on the cam? 2 little lines.
Old Oct 24, 2012 | 07:29 AM
trober_603's Avatar
I do but for example in tht picture what if that cam was turned 180 but the lines still was horizonal would it still be off timing?
Old Oct 24, 2012 | 07:31 AM
trober_603's Avatar
Do u have a picture of the cam lobs as well when its in that position?
Old Oct 24, 2012 | 12:08 PM
JustRandy's Avatar
It can't be 180 out of time because the plug fires every TDC. So, it doesn't matter if the lines are flipped the other way.
neilbedwell
Nov 10, 2018 11:02 AM
robj
Jun 15, 2015 08:45 PM
jag6510
Jun 15, 2015 05:59 PM
Steven Bandemer
Jun 9, 2015 08:50 PM
Steven Bandemer
May 27, 2015 07:39 PM
