Suzuki 185 Quadrunner - Issues?
Old Nov 23, 2012 | 12:06 PM
Bond-007's Avatar
Default Suzuki 185 Quadrunner - Issues?
Just purchased this from a guy on the net. This is my very first ATV. Just wondering if anyone knows of any issues I should keep an eye out for or good mods that should be placed on the priority list. Thanks for reading
Old Nov 24, 2012 | 06:06 PM
Toaster556's Avatar
Pistons are nearly impossible to find, and there's not much else available for them.
However, you can take a LT/ALT/ DR/ DRZ 125 top end and install it for a square bore/stroke of 57/57mm. The popular big bore kits for the 125 will also work, if you sleeve the cylinder down to accept the smaller piston. You'll end up with a reasonable spike in compression. Good mods are to use a DR200 or LT230/250 cam. I would exercise caution in making the motor too fast, the chassis just can't keep up. It would make a good 200 class flat tracker for a kid or someone doing it for fun
COFatboy
May 2, 2020 12:06 AM
Bulgin88
Aug 1, 2015 06:39 PM
Bulgin88
Jul 30, 2015 05:20 PM
Jul 15, 2015 02:07 AM
bikedad3
Jul 2, 2015 02:15 AM
