rear axle shaft in 2000 quadmaster
Old Dec 2, 2012 | 11:04 AM
brinson's Avatar
Default rear axle shaft in 2000 quadmaster
just installing a new right rear axle shaft in a 2000 quadmaster 500. first problem is the installation diagram I printed from OEM showing the rear hub. It cannot be installed as shown in the diagram, it must be reversed in order to seal. 2ndly I cannot get the hub to seat tight against the brake drum. When the nut and washer are tightened there is still an 1/8" gap between the hub and brake drum. Is it possible they gave me an incorrect shaft ( too long) or am I missing something/
Old Dec 12, 2022 | 02:22 PM
Larry caizzi's Avatar
Default Quadmaster 500
mine does the same thing did you fix it
Old Dec 13, 2022 | 03:40 AM
Don't know that model at all. We started selling Suzukis in 06 but LH and RH may be different lengths. Also all 500s seem to have got the LTA/LTF prefixes, and there could be confusion between your model and the Vinson, so dealer may have given you the wrong part. Check, with an on-line parts list such as partzilla, if the part number you got is the right one.
Remo Corine
Mar 5, 2013 07:36 AM
Entomber
Apr 1, 2008 02:43 AM
sethaloo
Apr 18, 2004 12:41 AM
dirtbikejunkie
Oct 17, 2003 09:51 PM
AZDUNNER
Jun 20, 2002 11:35 PM
