Tire bead
Old Dec 20, 2012 | 08:25 PM
blazin461's Avatar
Default Tire bead
A couple days ago, I had my KingQuad 700 out on a trail. I ran over something and heard a "pop" sound. Like I had punctured a tire. I was barely moving 1 or 2 mph at the time. I soon noticed that I had very little tire pressure in my right rear tire. Babied it back to my truck and got it loaded on the trailer. I got a better look at it and found what looked to be a small cut. So I assumed I had a puncture. Got it home and put about 20 psi in that tire and put some leak test fluid on the spot and it did not bubble at all. So I figured I did not have a puncture. As the fluid ran down the side of the tire it spread out where the rim meets the tire and it bubbled up big time. So I new then that I had a bead problem. When I took it into my local shop, he said I just blew a bead and they re beaded the tire, I also had them put in some Quadboss tire sealant in all 4 tires as well.
My question is.....is blowing out a bead on a tire a common problem? I believe the tires are original on this quad. 2007 KingQuad with 2275 miles on it. I am a new 2nd owner. They are not radial tires either. I do plan to replace them with radials down the road.
Old Dec 20, 2012 | 08:51 PM
dsldug77's Avatar
I have owned several Suzuki's including 2 king quads. I have never heard of that particular problem before. I have had some air leaking around the bead before, all I had to do was clean the bead and reseat it and all was good. I would chalk it up to bad luck.
Old Dec 20, 2012 | 11:14 PM
cbrandon's Avatar
I have only ever seen one bead pop and I been riding for about 15 years. It was just a perfect hit sideways on the tire right where it touches the rim and there was a fair amount of speed involved. We thought that was crazy that it popped the bead even then. You'll probably never have it happen again.
Old Dec 21, 2012 | 09:24 AM
LT80's Avatar
LT80 Expert
If you haven't ever had a bead pop off, you haven't been riding hard enough!
Old Dec 21, 2012 | 12:38 PM
Yep, I've seen it happen more than once myself.
Old Dec 21, 2012 | 06:19 PM
blazin461's Avatar
Well, it sounds like it is something that just happens, but let's hope it's few and far between. From what I have read, the Quadboss tire sealant will help this senario as well.
Alex G.
Sep 11, 2017 11:38 PM
Sep 30, 2015 01:37 AM
Ahtatu
Sep 28, 2015 12:14 PM
PinkFloydEffect
Sep 25, 2015 06:31 PM
cboler9
Sep 24, 2015 08:35 PM
