lt80 rebuilt wont stay running?
Old Jan 10, 2013 | 05:18 PM
rwelder's Avatar
Default lt80 rebuilt wont stay running?
i have a 92 lt80,just rebuilt top end(new cylinder/piston),brand new carb(OEM),new reed(OEM),new petcock(yamaha warrior to eliminate vacuum on carb),new starter,clear fueline. it will run for a few minutes then shut off. wont restart unless it sets for awhile or i empty carb. i have another lt80 that i did exact same changes to and it runs like a champ. i'm running out of idea's. got any? willing to try anything!
Old Jan 10, 2013 | 08:26 PM
LT80's Avatar
LT80 Expert
"wont restart unless it sets for awhile or i empty carb"
Hmm. Ok, When this happens, are you riding it along or sitting and idleing?
When it shuts off, is the plug wet (flooded)? What does applying the throttle do to it when it's quiting (spit/sputter/bog)? When it quits and you try to restart, the motor does spin over, right?
Well I guess we should do something, right or wrong.
I'd swap out the coil/CDI from the running machine. That should eliminate that aspect.
After that, the carb.
Let's go from there.
MikeyBoyesq
Nov 27, 2020 02:44 PM
chinkapin
Jul 14, 2016 06:58 AM
Ringwood
Jun 27, 2015 03:02 PM
yagerzzz
Jun 24, 2015 07:45 AM
jayking232003
Jun 9, 2015 02:54 PM
