carb problems...
Old Mar 23, 2013 | 07:02 PM
trober_603's Avatar
Default carb problems...
i just put a moose carb rebuild kit on my 92 lt230e quadrunner and it starts but is just extremely rich it wont idle if you left off of the throttle and it is just pooring out blue smoke(fuel), seem like the bowl is holding to much full tho how do u adjust the float level? i put everything back to how it was when i took the old stuff out
Old Mar 23, 2013 | 07:14 PM
trober_603's Avatar
then the idle goes up when i put the choke on im sure i dont have the idle set right but i think its just filling up the bowl to much and its just pumping full into the engine
Old Mar 24, 2013 | 02:02 AM
Jschmidt3's Avatar
You might have set the needle wrong.
Old Mar 24, 2013 | 09:24 AM
trober_603's Avatar
Which needle cuz no matter how far I turn in or out the idle or the small screw next to it(air / fuel I think) it doesn't change how it runs, just continues to dump fuel in. I also put the clip in the same notch on the throttle needle as the old on, second from bottom.. How do you know if there's to much fuel in the bowl idk how to adjust the float?
Old Mar 24, 2013 | 09:30 AM
LT80's Avatar
LT80 Expert
You need to get back into the carb and check things out. Something still isn't right.
Pay special attention to the float needle/seat.
Old Mar 24, 2013 | 09:43 AM
trober_603's Avatar
I'm assuming the needle on the float isn't sealing off causing to much fuel to come in? Just bend the float down or what?
Old Mar 24, 2013 | 09:59 AM
LT80's Avatar
LT80 Expert
I don't know...Get back into it and see what's going on.
Eliminate the "assumtion" part.
Old Mar 24, 2013 | 10:17 AM
trober_603's Avatar
Lol alright
Old Mar 24, 2013 | 04:49 PM
trober_603's Avatar
Still no luck I can get it to run but it just dies I had to put the e clip farther up on the throttle rod and that helped but still can't figure it out
Old Mar 24, 2013 | 10:25 PM
JustRandy's Avatar
Terms first.
The jet-needle is the thing you call a throttle rod. Everyone just calls it a needle.
The brass thing the needle goes in to meter the gas is the needle-jet. They come in a wide range of sizes.
The float needle is the thing that shuts off the gas in the bowl.
Diagnosis:
Since you made a change to the needle to affect the idle, I can tell your idle speed is too high. You should be able to idle without the needle even installed!
Is your replacement pilot jet the same size as the old one?
Actually, what all did you replace?
There is an airjet that feeds air to the needle-jet, is that clogged?
