suzuki gocart...need help with wiring
Old Mar 29, 2013 | 04:29 PM
brewsack's Avatar
Default suzuki gocart...need help with wiring
Ok...so I bought this gocart with a Suzuki atv motor and rear in it.. my problem is I have no idea what year it is. So finding the proper wiring is kinda hard to find. I wanna go to bare minimum wiring with no lighting. Well it was running and I wanted to go thru the wiring cause of all the splices. But I got excited when I seen snow and rode it.. after I came back and shut it off then no spark.. well I found the switch was shot. So I wanna take it back to bare min to make all my own harness. The only numbers I have are the 153 cm3 which is on the jug and the block is g402-100420. From what I found it looks like its off a lt125 with reverse.. it is old and was told the motor was redone. There is 7 wires. 3 yellow a blue a green and brown.. I need help finding where all wires go.. as said bare minimum..I got two wires I don't know where they go.. Orange and red out of box are not hooked up and brown out of motor.any help is grateful
Old Mar 29, 2013 | 09:47 PM
brewsack's Avatar
Ok sorry I didn't introduce myself. But I am chad. This is a project for my son and I. I have about as much info on this as you. So with that said, I am new to this. I have work on stuff my whole life but never really worked on this stuff since I lived in a city. But now I am in a farming area. So anyways, I am eliminating everything including switch. All wiring is still stock. But I traced and eliminated a lot of splices. I have no spark and would like to know what to wire. So any help would be nice.. thanks
Old Mar 29, 2013 | 10:05 PM
Jaster94's Avatar
you're going to need to know how many wires are coming out of the stator and how many pins are on your CDI. it almost sounds like you went to ground which is why you lost spark.
Old Mar 29, 2013 | 10:33 PM
brewsack's Avatar
Without uploading I can tell you that there are 7 wires coming out of the motor. 3 are solid yellow and go to the box. 3 go to the coil. Which are still in harness. I have 3 wires that are not connected. 1 wire out of motor which is brown and 2 wires out of the box which are red and Orange.
400H0
10
Aug 20, 2015 07:34 PM
Backwoods_badass
Aug 2, 2015 10:40 PM
Bulgin88
Aug 1, 2015 06:39 PM
DeFox500
Jul 26, 2015 06:32 PM
Jul 15, 2015 02:07 AM
