sleeving my 88 lt250r
Old 03-30-2013, 10:58 AM
RideOrDie88's Avatar
Default sleeving my 88 lt250r
I have to sleeve my cylinder. What I was wondering is can I bore the cylinder out big enough to fit an 85-86 sleeve and then just use those pustons as well. Or are the ports and pistons way different on the 85-86. Im just trying to get bigger than 69mm.
Old 03-30-2013, 02:16 PM
LT80's Avatar
LT80 Expert
Wow.
Are you planning on doing this yourself?
Why would a 85/86 sleve have a bigger bore? And if it does, it'll have a different stroke. So I'm thinking no.
You need to go to:: SuzukiquadracerHQ.com and ask the Zuki fellas.
Old 03-31-2013, 07:26 AM
Scooter86's Avatar
Knows Old ATV Questions!
Don't know if it is possible, but I wouldn't bother. They are two completely different motors from '86 to '87. The later models are both more powerful and have more potential. Are you having a hard time finding the correct piston or something?
Old 03-31-2013, 12:52 PM
knjlexus's Avatar
I have a cylinder laying around that i plan on big boring. It was sleeved before i got it and when the piston skirt broke during shipping i was screwed because they over sized the bore for the sleeve. I pressed the sleeve and shim out and plan fitting a trx250 sleeve in. 72mm
Old 03-31-2013, 12:53 PM
knjlexus's Avatar
Port layout on 85,86 sleeve will not work or match.
Old 04-01-2013, 07:13 AM
Ok thanks guys. I was just trying to get a bigger bore. I didnt figure it would work anyhoe I was just curious. I might try a trx sleeve. Or if u wanna get rid of urs(knjlexus) I might be interested. My piston skirt is broke as well thsts why im trying to get a little more power outta this thing before I put it back together
Old 04-01-2013, 08:07 AM
LT80's Avatar
LT80 Expert
You could send it to a motor builder and have a big bore sleeve installed.
I'm not a LT250R fella but I bet someone makes a big bore kit.
That's what a TRX250R has to have done.
Old 04-01-2013, 09:35 AM
knjlexus's Avatar
The sad part is their is no specific big bore sleeve for the 88+ lt's. Fitting a trx sleeve is challenging due to the casting of the cylinder. The sleeve will practicaly be your transfer port wall.I have not gotten a sleeve yet but I noticed they are quite inexpensive. I just can't get myself to throw away the jug so I will make it work.
Old 04-01-2013, 10:23 AM
LT80's Avatar
LT80 Expert
This morning I asked the guys at the zuki forums who makes a big bore kit.
No reply as of yet.
I liked the 310 kit on my R.
Old 04-01-2013, 01:28 PM
Yeah im pretty sure they dont big bore sleeves without having like CT or someone custom build one. Ill probably just give them a call cause they do a lil zuki work ive read. And thanks lt80
Quick Reply: sleeving my 88 lt250r
