1995 LTF250 Oil Seal Leaking Bad
Old May 6, 2013 | 01:59 PM
ChipNH's Avatar
Default 1995 LTF250 Oil Seal Leaking Bad
I need to replace the Oil Seal that is in the front of the engine for the secondary output shaft (I think that's proper term). I have a manual but the description on how to replace the seal is not clear at all. It almost looks like the crank case needs to be split to replace this..but I sure hope that isn't the case. Has anyone ever replaced this seal...or seen a documetn that describes the procedure?
Thanks, Chip
Old May 10, 2013 | 11:23 AM
ChipNH's Avatar
After checking the Serial number I guess it's not a LTF...looks like it's a LT4WDS...not that it matters.
exmotocrosser
Sep 13, 2019 06:12 AM
Scooter's Shop
Oct 9, 2015 02:09 PM
wrencher82
Sep 28, 2015 10:02 PM
Ahtatu
Sep 28, 2015 12:14 PM
wrencher82
Sep 24, 2015 03:39 PM
