LT160 hard start and midrange throttle issues
Old May 7, 2013 | 09:43 AM
jimdean33's Avatar
Default LT160 hard start and midrange throttle issues
Hey guys just joined the forum after lurking for a while. I have an '89 lt160e that I can only start with ether when cold and it idles fine when warm. It will choke out when given throttle. I can work it a little and get it to rev after a while but it still bogs down in the midrange.
I have rebuilt the carburetor with oem jets per the service manual,
checked the float height per manual,
checked and adjusted valve clearances,
adjusted cam chain tensioner,
changed the oil and filter,
replaced the battery,
checked resistance over ignition coils,
checked spark at plug (it was blue),
and replaced the spark plug.
I have not checked the timing. I currently have the cdi off to check resistance. I am getting no readings across several of the terminals.
Do you guys have any suggestions?
Old May 8, 2013 | 08:14 AM
LT80's Avatar
LT80 Expert
Welcome to the forums.
IMO, It's a compression problem.
Old May 8, 2013 | 09:22 AM
jimdean33's Avatar
LT80, thanks for the reply. I forgot to mention that I checked the compression and was reading 180 psi after 6 rotations.
Old May 8, 2013 | 12:29 PM
LT80's Avatar
LT80 Expert
Okey dokey..LOL
Providing the timing is correct, I agree to look toward a electronic problem.
Old May 9, 2013 | 07:15 AM
jimdean33's Avatar
Bump for more suggestions.
Old May 9, 2013 | 07:45 AM
j_mauld's Avatar
I would be looking at the float.
Is the float full of gas, or if it's plastic has it absorbed gas over time?
Also, when you set the float height, try setting the height where it first makes the needle seat into the valve. Don't set the height where the float rests freely when the carb is turned upside down. It's easiest for me, if I hold the carb upright when I'm setting the float height.
chinkapin
Jul 14, 2016 06:58 AM
BEEFKING69
Jun 17, 2015 12:38 AM
Steven Bandemer
Jun 9, 2015 08:50 PM
ds-newbe
Jun 3, 2015 05:40 PM
1000gade
May 27, 2015 12:37 PM
