1983 lt125 transmission
Old May 27, 2013 | 02:35 PM
Dammar's Avatar
Default 1983 lt125 transmission
picked up a pair of 83 lt 125 for 30.00 one motor nearly runs but trans locked up other motor been open to elements (no oil cap or carb or spark plug but turns over by hand) tore into lock up sheared teeth on two separate gears, tore into other motor found pieces in bottom of case but gears looked good, finally found 4th gear driven cogs sheared off darn it same gear as lock up.. any one happen to have one laying around just taking up room you need to get rid of?? also could use complete recoil starter (lock up has some sort of electric starter on it no recoil other had none) could be interested if cheap enough or i'll just scrap it all thanks to all
Jeff Roper
Feb 1, 2022 11:48 AM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
r1pilot83
Sep 27, 2015 07:38 PM
WilliamBos
Sep 22, 2015 04:07 PM
Sep 1, 2015 11:59 PM
