Buying a 250 quad sport what should I look for
Hi just wondering if this bike has any bad traits. It's a 1990 250 with new piston, rings valves, bushing and bearings. Any help would be appreciated. Also does this bike have reverse or electric start? Thank you
It has a kickstart and reverse. Especially check the swingarm and rear axle bearings. They ARE KNOWN for those bearings. Check the shocks to see if they leak oil.If they don't leak, don't worry because they will the first time you grab big air on it like mine. The shifting will more than likely be loose because of the linkage. Also make sure the steering stem and clamps are straight and not bent.
Frisky2050
Apr 9, 2020 11:19 AM
toonces
Oct 16, 2019 12:11 PM
