LT80 Maintenance parts suggestions
Old May 30, 2017 | 12:29 PM
rowdog_14's Avatar
Default LT80 Maintenance parts suggestions
I got a LT80 the other day that looked to be in good shape. I drained the gas and cleaned the carb but just wanted to know suggested companies for replacement parts or just OEM.
1. Petcock-Searched Forum and found an ebay one a user suggested
http://www.ebay.com/itm/Suzuki-LT-80...pXFVeu&vxp=mtr
2. Head gaskets- blew the top one after about 4 rides after getting it
http://www.ebay.com/itm/291967420348...EBIDX%3AITTusk Top End Gasket Kit Set KAWASAKI http://www.ebay.com/itm/172648519165...%3AMEBIDX%3AIT
3. Carb rebuild kit- Is it really needed if all looks good? If so then which company
Amazon Amazon
http://www.ebay.com/itm/New-Suzuki-L...1ZCE7b&vxp=mtr
Amazon Amazon
4. Starter-Searched Forum and found an ebay one but are they really about the same as OEM and if so which company would be better suggested
Amazon Amazon
Amazon Amazon
Thanks
Old May 30, 2017 | 01:58 PM
DirtDevil101's Avatar
Petcock - I wouldn't replace with a stock vacuum unit, but rather a gravity fed unit..
Head Gasket - I'd use OEM personally...
Carb rebuild kit - if everything looks good and it was running fine no need...
Starter - Is there something wrong with the current one? I'd guess they are the same Chinese make just re-badged...especially at that price point...
Old May 30, 2017 | 02:09 PM
rowdog_14's Avatar
Ok thanks,
I must have added the wrong link. My search on Petcocks was to get a gravity. I will check my URLS again,
Ok on the OEM head gasket
Carb, yeah everything seed fine when the engine was running
Starter- I think I burnt it up when the engine stopped working. I was trying to start it over and over. It now gets hot on shots runs and make the wiring verrrrry hot under the seat.
Old May 30, 2017 | 02:23 PM
You might want to think about a pull-starter...not cheap at $100, but I hate relying on a battery as you cant jump-start these autos...
I have the cheapo replacement starter in mine...they work fine...
Old May 30, 2017 | 02:40 PM
rowdog_14's Avatar
No they are not cheap the one I found was $89 and the electric starter was $28, but getting to the starter looks like a pain in the AS-!!! I tried my luck yesterday without taking apart everything and I was not able to get it out . So I think it would be worth it, just in case the electric craps out again. Plus like you mentioned you can not jump start these like clutch ATV and Bikes.
Old May 30, 2017 | 02:44 PM
LT80's Avatar
LT80 Expert
FYI: The ebay starters have worked fine.
No matter what petcock you use, I still put a inline shut off close as possible to the carb.
It seems that running the carb till empty avoids a lot of carb problems. It just saves time.
Old May 30, 2017 | 03:40 PM
Rowdog - you need to perform the footrest modification (look it up - I think I even posted pics)...that will ease your suffering a bit
Old Jun 3, 2017 | 10:58 AM
rowdog_14's Avatar
What is the footrest I tried searching but really did not see anything.
Also, got it back up and running. Smooth as a whistle now. Starts at a kiss of the button. Makes me wish I did not get the pull start, but hey got a backup now.
Old Jun 3, 2017 | 12:39 PM
LT80's Avatar
LT80 Expert
Ya know those things that your feet rest on? LOL
Considering that we should believe in maintaining the clutch's, the footpeg mod is a great help.
Old Jun 4, 2017 | 06:10 AM
rowdog_14's Avatar
Forum would not let me edit kept saying I was not logged in even after loggin in. I tried adding 'mod' after footrest. Either way between having a TL1000,VTX1800, XR80, this LT80 for some reason I never knew they were called footrest and foot pegs...
ok but seriously you still did not offer direction to my request even with my typo. What is the footrest mod I tried searching but did not find anything?
