2004 Eiger flywheel removal
Old Sep 2, 2017 | 07:34 AM
AAB's Avatar
AAB
Default 2004 Eiger flywheel removal
My Eiger will not run. Carb is good, check electric circuit, CDI and coil whick check ok. The stator resistance is good. Based on info found on the internet it is probably the flywheel magnets. The spark will fire for 1-2 seconds, then no spart, then a few seconds later there is spark. What is the process for removing the flywheel?
Thanks,
Old Sep 3, 2017 | 02:29 AM
In my opinion the "loose magnet" information on the net is rubbish. Yes I have had an Eiger with a loose magnet, it completely destroyed the stator, so I can't see how a bike can continue to spark once this has occurred. You will soon find out if you take the alternator case off. Be warned, on manual versions the case contains loads of gears and washers that drop off when you split it, almost impossible to work out how they go back without a parts book or workshop manual.
Amtrack
Sep 22, 2016 10:08 PM
champ198
Aug 22, 2016 04:57 PM
jpcjguy
Aug 18, 2016 12:31 PM
MikeMc48
Aug 17, 2016 03:49 PM
wwtbuick
Jul 17, 2016 11:13 AM
