LT80 nightmare
Old Apr 3, 2018 | 06:38 PM
Webb1776's Avatar
Default LT80 nightmare
So where to start my son's LT80 stop running a couple months ago. Naturally I assumed I had a carburetor issues or the peacock valve. After replacing those two items and ensuring I had a spark I started doing my homework thus finding this page. After all the post I have read the next natural thing would be compression I did a compression test today and it was only 60 after spraying WD-40 in it so off comes the cylinder head and The Jug to my surprise the cylinder walls and all the gaskets are pristine so I am totally stumped no idea why I would not have compression when everything looks brand new even the Rings look great any help would be appreciated thanks in advance
Old Apr 4, 2018 | 08:41 AM
LT80's Avatar
LT80 Expert
Measure. Just because they look good doesn't mean that they are not wore.
Welcome to the forums.
Old Apr 4, 2018 | 11:06 AM
DirtDevil101's Avatar
Could just be worn rings...top end rebuild is pretty cheap and considered normal maintenance on just about any 2-stroke...kinda missing the nightmare part...crank grenading and blowing a hole in the case is nightmarish...
Old Apr 4, 2018 | 02:54 PM
LT80's Avatar
LT80 Expert
I'm not a re-ring kind of guy. If the rings are wore, I figure the piston is wore too.
Old Apr 4, 2018 | 03:12 PM
C'on Jack...you know me...I'd never just re-ring it...a fresh top end means all the goodies...all the goodies are still cheap...
Old Apr 4, 2018 | 04:48 PM
LT80's Avatar
LT80 Expert
I know you agree, just making sure everyone knew.
Old Apr 5, 2018 | 03:15 AM
Could be worn rings, but if there is no step in the bore---. There are other possibilities, head gasket gone, reed valves stuck or broken, just saying.
I do fit new rings to old pistons, but I am a tight wad.
Old Apr 5, 2018 | 07:05 AM
Webb1776's Avatar
thanks for the advice
I'm going with a new top-end any suggestions on brands and should I go bigger than stock should I replace the reeds and go with bigger jets
Old Apr 5, 2018 | 09:03 AM
LT80's Avatar
LT80 Expert
You should have your Suzuki cylinder bored to a next size bigger Suzuki piston.
Yes, you could get a china junk top end. FYI: they are all the same with different labels.
No jetting changes are needed.
Boyesen reeds are fine but not needed.
Old Apr 5, 2018 | 10:44 AM
Webb1776's Avatar
so what is the stock size of the piston and bore Im new to this and want to get every thing right
