2001 LT 80 starting problem
Old Jun 25, 2018 | 08:19 PM
Jimmy J's Avatar
Default 2001 LT 80 starting problem
I have a 2001 LT 80. it cranks but then loads the cylinder up with gasoline and can't turn over. I pulled the spark plug and a lot of gas shot out of plug hole. I cleaned out the carb jets and float bowl but it still does the same thing. is it maybe leaking past the needle valve and flooding the chamber? After I cranked it over to get the gas out of the cylinder I dried the plug and it started with the gas shut off, then stalled. When I turned the gas on it cranked but no start. Then it turned over very hard . No gas in cylinder this time. Ideas? Jim
Snowcatxx87
Jun 15, 2018 06:51 AM
2001Warrior3fitty
Jun 14, 2018 06:30 AM
woodr004
Apr 23, 2018 02:12 PM
Domi1983
Apr 23, 2018 06:34 AM
ken270
Apr 16, 2018 03:53 PM
