Suzuki LT80 Crank seals
Old Aug 13, 2018 | 04:17 PM
cbn700's Avatar
Default Suzuki LT80 Crank seals
Hello,
Looking for some advice. My nephew has a lt80 and it would not run. Long story, but it traced it to the stator side crank seal is bad. Removed the flywheel and stator and crank seal just fell out. Bought an oem seal and it will slip in to the lip on the outside, but it will fall out as well. Do these need to be installed to a correct depth or need a sealant installed on the outside of the seal? thanks
Old Aug 14, 2018 | 08:21 AM
LT80's Avatar
LT80 Expert
Welcome to the forums.
I push them in till the lip on the seal contacts the case. I coat them with a lil grease.
Never had any fall out before.
Old Aug 14, 2018 | 08:47 AM
cbn700's Avatar
That does not seem like a lot to hold them in. They are not very tight
Old Aug 14, 2018 | 02:18 PM
cbn700's Avatar
well put them in like you said, and put it back together and now it is running. thanks
Old Aug 14, 2018 | 03:08 PM
LT80's Avatar
LT80 Expert
Eaglecollector
Mar 14, 2025 12:20 PM
iron
Oct 25, 2009 08:15 PM
ixnas
Dec 18, 2006 01:18 PM
cwt
May 15, 2004 10:38 PM
dinksdairy
Nov 23, 2002 01:02 PM
