Lt80 2005 seized?
Old Apr 4, 2020 | 04:37 PM
  #21
Shoooter's Avatar
IT RUNS!!! But how it only runs with the choke on. Everything was cleaned could it be something with the needle valve?
Old Apr 4, 2020 | 04:38 PM
  #22
LT80's Avatar
LT80 Expert
First thought is that the carb is poring gas into the motor. Many float needle problems as of late. Also, reading again, you mention fuel coming ouit of the petcock when in run position. Fuel should not flow when in run position. Might as well get a blaster petcock, plug the vac port that sends vacuum to the factory petcock.
In the meantime, remove spark plug, put a rag on top of spark plug hole and turn the motor over. This is to blow raw fuel out. Be sure to put the plug wire far from hole. Replace spark plug. Disconnect fuel line from petcock. Drain the carb. Apply full throttle and spin till it spits and sputters then revs up.
Let's go from there.
Old Apr 4, 2020 | 10:38 PM
  #23
Shoooter's Avatar
I finally got it to fire after cleaning the carb . But it wont run without the choke on. It pulls hard and doesnt sputter. Maybe it needs a carb rebuild?
Old Apr 5, 2020 | 08:20 AM
  #24
LT80's Avatar
LT80 Expert
I'd do a compression test.
Old Apr 5, 2020 | 09:37 AM
  #25
Shoooter's Avatar
120psi
clgodwin79
May 18, 2025 09:44 AM
jasondemitri
Apr 8, 2012 10:05 PM
bsb64
Jun 7, 2003 11:27 PM
