Lt80 crankshaft assembly
Old Aug 3, 2020 | 05:05 PM
LT80's Avatar
LT80 Expert
I think welding the pin is something that's sorta just done by crank shops. I could be wrong. Wife says I am all the time.
Old Aug 3, 2020 | 06:12 PM
no_whereman's Avatar
Hmm. My last replies don't show up.
I did talk to them about welding pin. They say they never had a issue with "pin walking" on these cranks. But with the banshee cranks they do, so they weld them. I'm gonna try them,hope it goes good.
Old Aug 3, 2020 | 06:15 PM
They further say, Once a crank is welded that's it, it's no longer rebuildable in their opinion.
Old Aug 3, 2020 | 06:47 PM
LT80's Avatar
LT80 Expert
OK, good info.
I'm sure they will do a fine job.
50 bucks for a head
Old Aug 3, 2020 | 06:55 PM
  #15
Ok. I'll see if son will let lose of 50 . thnx
Old Aug 4, 2020 | 07:30 PM
  #16
Hey Jack, sounds like he wants the head. I sent you email. Let me know.
Old Aug 13, 2020 | 12:49 PM
  #17
The snail mail is killing me. Some parts are suppose to be arriving today. Once all parts are in hand I'll assemble. Kids will miss next race.
Few question before I begin...
1. The old crank seals have a little nub on edge and seat in case has a small divot. The new seals do not have this nub, Issue???
2. As mentioned by others, I'll fit new heated bearings to cold crank. Do I side bearings onto crank as far as they can go???
3. I'll heat left case and install crank, then heat right case and install onto crank???
4. Bearings seem un-directional, doesn't matter which way they go on crank???
5. There was no gasket between case sides, should there be one? Or is it just some kind of liquid gasket, form-a-gasket???
6. Two stroke so everything is lubed by the oil mix ratio, no oil in bottom? I was going to apply a bit of assembly lube to bearings and seals so no dry start up wear. Good to do???
Hope all are well,
Eric
Old Aug 13, 2020 | 01:16 PM
  #18
LT80's Avatar
LT80 Expert
I'll get on the head.. sorry.
1) Install the seals till they are flush. Suzuki seals have that lip.
2-5) Sand the crankshaft till the bearings barely slip on, and yes, all the way up to the crank end (there will be a space). Remove the bearings. Throw the crank in the freezer. Clean/sand the guide pins and holes in the cases. You want the cases to be able to slide together w/o turning the bolts to draw it in. After the crank has had time to shrink, heat the one case 1/2 up till the bearing literally falls in. Put aside to cool. Do other case 1/2 and bearing same way. While a tad warm, apply layer of sealant (yamabond/hondabond/tribond) to the case 1/2's. Take the crank and put it in the right case 1/2, then stick it in the other case 1/2. Like I said, it should slip right on. Then tighten the bolts.
6) No oil in bottom. I use a layer of grease on the seals. I use 2 stroke oil on the pin brg, pin, piston and rings for assembly.
whew...lol
Old Aug 13, 2020 | 02:20 PM
  #19
Thanks Jack!
Your detailed info is fantastic. Greatly appreciate your reply.
Old Aug 14, 2020 | 04:24 PM
  #20
Default Case sealant
Is one case sealer better than others? All I find local is yamadond 6. Shop said once it's together it ain't ever coming apart. That worries me. What do you all use?
blevinsbulldog
Oct 26, 2011 04:12 AM
