1992 Suzuki LT230E
Old Dec 13, 2020 | 01:52 AM
67Camaro's Avatar
Default 1992 Suzuki LT230E
Still having fuel overflow issues despite rebuilding the carb with new needle and seat, setting float height and checking float for leaks. I would prefer to replace the entire carb but cannot find one. Anyone out there know of a good aftermarket carb I could get?
Old Dec 30, 2020 | 10:56 PM
Michael Horsford's Avatar
bud i have a 92 also fun machine light good power .... I added a decent mild piston kit to mine ported head added a cam & the big difference was i added a 30mm nibbi racing carb it really woke it up ... Starts up like its new perfect idle hot cold doesnt matter ... It was 125 on amazon ....
Old Jan 1, 2021 | 04:05 AM
I don't know those early Suzukis, but most Suzukis have a vacuum operated fuel tap and if you leave it on prime you will get problems. OK the float needle should stop fuel flow, but on other makes an overflow pipe runs fuel onto the ground, Suzukis don't have this because the tap should shut fuel off as soon as the engine stops, as long as you have the tap on run. As for the carb, once dirt is in the tank, it will keep jamming the float needle open, a new carb will do exactly the same. An in line filer would help, but they tend to air lock if run dry, as it would between running out and going onto reserve.
Old Jan 1, 2021 | 10:07 AM
67Camaro's Avatar
I've found that the motor does not have proper cylinder pressure/compression. I measured 100 lbs. and the service limit is 145 lbs. Pulled the head and cylinder and found a broken ring. Cylinder is good and in spec. for a standard piston/ring set. May be able to use the old piston. Thanks for the comments.
67Camaro
Dec 30, 2020 11:05 PM
Fender bender
May 15, 2014 02:13 PM
BFD35
Nov 2, 2012 04:00 PM
Redeemed
Nov 8, 2005 12:01 PM
